Hi
I’ve done some searching already and cannot find an definitive answer to my question. Also, sometimes a new thread can draw out very specific answers so here goes.
My van is a 2018 Startline window van. It is very basic, perhaps too basic, so I’ve been adding additional electrics. So far I have 4 piggy back fuses in the lower centre dash fuse box. Dash cam, 2 x USB and a rear 12v outlet in 4mm cable. This feels a little wrong and un sustainable!
There are no thick red cables under either seat.
I need to install tow bar electrics which head for underneath the passenger seat.
At some point in the future I may want to install a second battery and/or solar.
I’m looking for a solution that deals with the current and caters for future adaptations.
My current (no pun intended) thinking is to route a thick fused Permanent live cable (30 or 50A) from the unit under the battery to under the passenger seat. Install a fuse box with perm and switched live sections (using dashboard switched signal feed) then run all new circuits from there. Hopefully this will satisfy the towbar feeds. Also, I’d like this to be phase 1 of subsequent additions ie split charging and solar feed.
Can anyone advise what I need to do and materials needed, particularly the connections / fuses to the main control unit under the battery?
With these complex upgrades its often good to chat so send me a message if you are willing to receive a phone call.
Ian
Ian
