Additional USB sockets activated on ignition
mike2060
Hey there. I am looking for a way to add additional USB socket that would:
  • be used to power two wireless chargers 15W
  • be on only when ignition is on.
  • be hidden somewhere behind all the plastics - I found a way to route the cable out and to the chargers on the passenger side, not yet started on drivers side
Can someone advise where to look for a wire to hook up into to pull the power ? I assume some 12/24V. I was thinking of using something like this one from amazon
Thank you!
Why did you pick this particular fuse?
I did not strip the DSG pillar yet. To be honest, I never noticed there might be a fuse box there, so originally I was thinking of hooking up to the F16 30A fuse in the driver side fuse box, marked F16 here in Fuse Holder C. It is described as Onboard supply control unit -J519-Windscreen wiper motor -V-. A note here - UK vans may have this diagram mirrored.
Would that work ? The rest as in your post (5A fuse). I won't have any additional usb ports at there, just for those two chargers.
