My van a T30 was lowered by the previous owner and by the looks (purple) has Stance fitted.
Since conversion to camper have developed a saggy rear end .....
Advice appreciated on how to raise the rear ride height by say 20mm to match the front. Front measures 395 wheel centre to wheel arch, rear 375. Van currently drives and handles well.
a couple of questions
- from the photo is the Stance suspension fitted correctly ?
- can you just turn the adjuster ? if so how many turns to go up 20mm ?
- by adjusting the spring will it make the ride harder ? and more likely to break a spring ?
- do i need to replace stiffer springs to match the increased weight in the van ?
Thanks in advance
Peter
Thanks in advance
Peter
