Hello, so i have hooked up a Victron 12/12 30 to a deep cycle Gel acid carbon battery (link) . I have setup the charging routine as suggested by the battery supplier and been on several long 3+ trips. Victron goes into float mode suggesting it is 100% charged.
So i just hooked up a battery monitor and 6 12v small LED light to test everything out and check the level of the battery and checkout the new battery monitor (Battery Monitor BM2 )
So when i first turned on the lights it stated the battery was 98%, great i thought. i then turned off the lights and hit the breaker switch. I then turned it all on again and it then stated 86%.. umm ok im thinking in a 1 min period 6 led light to loose 12% is crazy. So i did a repeat of the process, turned off the lights hit the breaker , reloaded the app. and boom agian 75% !? . So i did it again but it now continuously states 75%. Does this point to the battery being faulty or is the monitor likely to be faulty ?
Not sure where to go with this. I must add the monitor is connected to the fusebox entry point and then earthed to the battery through the fusebox return.
Really not sure where to go with this as the battery has been on several long runs and the battery goes into float mode, indicating fully charged. but then the monitor states 75%.. the victron has also kicked in to charging in absorption mode.
Any help would be greatly appreciated.
Daniel
Daniel
