Thanks both of you. I had seen this one.I did exactly as per video using sikaflex Not had any problems what so ever
Hi all
I did a search and found nothing that was definitive
Does anyone have a documented process for fitting an aftermarket rear spoiler?
ThanksRoof-Spoiler fitting
Hi All, In the interests of doing my small bit to get this forum going with useful info, I thought I'd post a few pics and things I found when installing my rear spoiler the other night, so here' goes: Before...... Kit I used: Pre-painted spoiler from Banwy. On the more expensive side, but...www.t6forum.com
This has a fair bit of info, in case it didn’t appear in your search
I cleaned the paint surface with alcohol wipes, then sikaflex’d mine on. I luckily discovered a few months later when cleaning the van that the corners looked like they had slightly lifted. So I wiggled the spoiler and it was practically coming off - only held on by a few blobs gripping. I removed it easily by just giving it a tug - really lucky, we were going to go down the motorway that weekend and it may have flown off!Thanks both of you. I had seen this one.
My only question was around the fact the supplier told me today that i should rough both bonding surfaces with wet and dry. The video doesn't show that if I recall correctly.
Also what masking tape to use?
If I could go back in time I would do this. The fresh paint on the spoiler may have caused the problem, as it was only painted a day before fitting, and as I mentioned when it came off, there was zero sikaflex on the underside of the spoiler but all of it that I put on the spoiler before attaching had transferred and stuck to the van roof. I chose not to rough it up, as in my head I didn’t want to wreck the paint if I ever wanted to remove it. But that was a mistake.We would rough up the spoiler and the top of the rear tailgate - this will insure perfect adhesion. This is for bonding only. We don’t screw ours down as well. We’ve fitted hundreds like this with no issues.
Thanks. So just some fine wet and dry?We would rough up the spoiler and the top of the rear tailgate - this will insure perfect adhesion. This is for bonding only. We don’t screw ours down as well. We’ve fitted hundreds like this with no issues.
