Danpearson1986
Good evening.
I've purchased a volkswagen reverse camera input interface harness.
I have a discover media radio. I'm wanting to add a reverse camera to the radio.
The description for the harness says:
Adapter harness to add a reverse camera to an original volkswagen transporter T6 discover media radio screen. This harness has a built in interface to give ignition power and a reverse feed to the camera. Note: camera input function needs to be CODED to the van using VCDS.
so that being said.....
Video lead from the harness (yellow plug) - to video output on the camera. This also has a power wire small red wire which is attached to the video cable.
Ground- (black wire) - to ground on camera power.
Acc- (red wire) - to positive connection on camera.
Reverse - (Purple) ... Do I tap this into the green and black reverse power in the harness from rear passenger tail lamp loom, or do I connect the video cable small red power cable from camera video cable into the Purple reverse from the harness.
Also is the small black module a canbus relay.
Thanks for taking the time to read my post.
Dan.
Dan.
