I have a 75Ah Platinum Prestige AGM battery under the driver's seat that has significantly deteriorated after 2 years and I am looking to replace it. It is currently giving around 30Ah and does not hold charge well if left idle for a few days. Should I get another like-for-like AGM or a wet Lead Acid?
The 240v charging is via a Sargent EC155 Power Supply Unit. I have heard mixed advice as to whether the Sargent can manage AGM cells adequately, or if they are better with wet Lead Acid batteries. The Sargent cannot manage a lithium cell. I would like to avoid a wet Lead Acid battery if possible due to ongoing maintenance. I would also like to avoid adding a new 240v charger if possible. It may be an upgrade in a couple of years.
The van is a T6 with a Smart Alternator and a Durite VSR split charge for the 12v leisure battery charging. I know VSR split chargers are not good with Smart Alternators, but I have heard that they can be adequate in the short-term. I need to keep the VSR for a while, but plan to replace it with a Victron Orion DC-DC charger. I also have a PV Logic MPPT Pro - Dual Battery Solar charge controller.
My requirements are to power a JKF50 fridge and cabin lights for 2 to 3 days. The spec on the fridge is a 0.7A draw and the lights can draw up to 0.6A. I measured the fridge power consumption and the maximum draw was about 2.6A. About 50Ah would be sufficient for me, so I am happy with a nominal 75Ah battery capacity. I can live with changing a battery after 2 years, as at that point I might be ready for a more comprehensive upgrade.
Any thoughts gratefully received.
