Air ride fault
Simples
Morning guys. I’ve got a bit of an issue on my air ride set up and was wondering if anyone can help me out. I’m running airlift 3h3p management.
The problem is when I get in the van in the morning something is telling it to raise the rear right to say 120psi then it pretty much straight away dumps it back down to its last know setting. Thus causing the compressors to start up and top the tank back up. If I switch it from height see back to 3p the fault doesn’t happen. Is there anyway I can try and test to find out if it’s either a faulty height sensor of a faulty manifold? Has anybody else had a fault like this?
Or whoever fitted it as it has up to 4 year warranty depending on how you bought it.
Is it a recent install or an old install? Did you have it fitted or did you buy the van with it already installed?
If it’s within warranty and you had it done or know where it was installed, easiest thing is to ask the installer to take a look, diagnose and sort it.
