Hi all, Got my t6 aircon regassed but still not blowing cold just lukewarm and no errors showing the computer. When I look down the engine where the belts are the clutch isn't pulling in. Any ideas Thanks Sam
There is no electromagnetic clutch on this generation of A/C compressors.
The A/C ON switching is controlled by the compressor's built in valve.
These valves are common point of failure.
To get it replaced, the refrigerant needs to be pumped out. And then after replacement, the system has to be recharged again.
I was on you tube and they said there is a clutch on the pully wheel and when you turn on heater it starts to spin to make cold air. Or I have been looking at something else. Phone with red arrow pointing to the pully if you can make it out. It's the very bottom of engine. Hope this makes sense, Sam
I was on you tube and they said there is a clutch on the pully wheel and when you turn on heater it starts to spin to make cold air. Or I have been looking at something else. Phone with red arrow pointing to the pully if you can make it out. It's the very bottom of engine. Hope this makes sense, Sam View attachment 257703
