Thanks @Scottish Scrutineer for the reply. The alloys are 850kg each / 1700kg per axle. So hopefully it weighs less than 3400kg overall it'll be fine? Or we need to get below 3000kg as it's a T30?You need to weigh your van fully loaded (including passengers) to check that the weight does not exceed 3000kgs and the axle weights are not exceeded. You also need to find out what the weight rating of the wheels are.
Tyres are okay as that load rating is fine for a T32
The total mass of the vehicle can’t exceed 3000kg.Thanks @Scottish Scrutineer for the reply. The alloys are 850kg each / 1700kg per axle. So hopefully it weighs less than 3400kg overall it'll be fine? Or we need to get below 3000kg as it's a T30?
Thank you for the help!
lol, no kPa is kilo-Pascals - units of (in this case, tyre) pressure!!Sorry to resurrect an old thread but I've just got my 2017 T6 and thinking are my tyres correct. This I believe shows the KPA which I assume is KG per axle?
I have 255/40/19 100y extra load tyres showing 800kg are these ok?
There should be a plate under the bonnet.Thanks for replying, where do I find the axle load rating?
There's a sticker on the bulk head under the bonnet on the drivers side with the info on, add the bottom 2 weights together then divide them by 2 to get the axel wrightThanks for replying, where do I find the axle load rating?
