Has been fitted in my van for about a year and working perfectly. Am removing to replace with a different speaker. These sound excellent running on OEM headunit and are much much better than OEM speakers made of toilet paper or combine with amp and sub for abit more noise. All plug and play connections.
(Photos to follow)
Comes in original box.
£195 posted to UK address inc insured courier.
Upgrade your Volkswagen T6 with the new SPC-106T6 high-end component speaker system.
This Alpine Adventure Audio system for the Volkswagen T6 perfectly unites function with form: enjoy audiophile grade sound quality, while the beautiful photo-etched stainless-steel tweeter grills simply look stunning in your A-pillars.
The High-end tweeters let you hear every note with stunning clarity and fast dynamics, while the 16,5 cm mid-range door speakers produce a wide frequency range that uncovers the rich details of every audio track – delivering your favorite songs with powerful mid-bass and amazing texture and accuracy
Due to the original VW connectors and usage of the original wiring harness, installation is fast and easy. The system is also compatible with the front windscreen roller blinds in the VW T6 California and can be further upgraded to the Concert Ensemble with a powerful 300 Watts subwoofer and a 6-channel DSP amplifier.
Mid-Range Woofer
Alpine SPC-106T6
(Photos to follow)
VW T6 Alpine Component Speaker System SPC-106T6 – 16.5 cm
This is a great upgrade, which transforms the way you listen to music. Its all plug and play meaning self installation is easy to do.Upgrade your Volkswagen T6 with the new SPC-106T6 high-end component speaker system.
Mid-Range Woofer
- 166 mm mid-range door speaker
- Includes steel plates for solid door installation and adaptation to 200 mm door cut-out
- High quality steel basket and rubber surround
- 25 mm voice coil
- Large Ferrite magnet
- Includes foam seal ring
- For easy installation with original VW cable harness (original connectors)
- 28 mm audiophile-grade back-chambered silk-dome tweeters
- Neodymium magnet
- Stainless steel tweeter grills (photo etched)
- Acoustically optimized tweeter installation brackets
- Integrate speaker network with foil condenser
- Peak Power Handling: 180 Watts
- RMS Power Handling: 45 Watts
- Frequency response: 45Hz – 25kHz
- Impedance: 4 Ohms
- Sensitivity: 89dB 1W/m
