Hi guys,
I've got a Titan vari mount bed on order and just trying to sort out a Caravelle rail setup for it.
I was wondering a few things, firstly is it possible to fit the single seats in the middle column if you use the double rails, or is that literally only usable by the table?
Secondly if I were to fit the SWB rails into a LWB van, would it be possible to position them so that I could squeeze two rows of single seats in front of the titan Rick n roll bed?
And finally if I were to fit the SWB rails, can they hit all the same mounting points under the van as the LWB ones?
I've moved to Norway and the regulations are really tight here, I can pretty much only fit a bed that uses original mounting, hence the need for Caravelle rails, but I'm concerned that if the SWB rails don't hit the right mounting points then they will still fail it.
I also want to try and approve it for taking 4 passengers in the back, hence trying to squeeze in 2 single seats. You can't just add them as you want here, everything has to be rubber stamped.
Thanks for your help
Dave
Dave
