Alternative rear seat table
Mocko1962
VCDS User
Used cut down version of swivel table bracket to give table on rear seat and full size swivel bracket and table when double seat swivelled ... works for us as the big table blocks the kitchen area off restricts access to cupboards 20201018_125149.jpg20201018_125232.jpg20201018_125155.jpg20201018_125210.jpg20201018_125149.jpg
Standard swivel bracket and table from Kiravans Or Clearcut Campervan Supplies table finidh type to suit your van ..mine is not the same as the units but... suits me
Fit the bottom 'socket' type bracket drilled and self tspped into hard point (metal) of the van before the van wall chamfers down to the floor ... You will need a short piece of flatbar .. say 200mm long 40mm wide 4mm-6mm thick ... fix this to hard point of van at each end of the flatbar .. then position the circular screwknob clip on the straight section of pole .. mark holes in flatbar when the pole is straight.. drill flatbar and fix screwknob clip.. cut down pole heigjt to suit your preference when sat down
. Job done ... i covered my flatbar bracket with carpet luning to hide .. see 3rd photo down close up of brackets .. Bonne Chance
