Hi folks.
First Post, I've been scouring the forums/internet but can't find my specific problem.
I've had a ctek d250se on my van for about a year all running great. I finally added a renogy 175w flexible solar panel to my van yesterday and hooked it up to the ctek today. Connected positive to solar input and negative to the negative terminal on the ctek.
All seemed to be running fine, especially when the engine is on - solid solar light (when it's light out), solid alternator light and solid leisure battery light + solid green power light.
Since adding the solar panel and when the engine is off and the van is locked, I can see green power light on (normal) but the alternator light flashing away. The battery light has switched off which is semi reassuring as it doesn't look like its draining the starter, but I've never noticed the alternator light flashing when the van has been locked for a while.
There's no fault light, just the alternator pulsing away. Any ideas? The manual doesn't show what this light configuration means, nor have I managed to find anything online.
Thanks in advance if anyone can help me out!
