looking at this. . .
Official EcoFlow DELTA portable: Power Source: AC/DC ✓ Battery Cell Type: Lithium Ion Click to learn more!
uk.ecoflow.com
it shows 8A MAX for car charge . .
so are we saying you unit is pulling more that 8A - is it older FW that is drawing much more?
Car Charger Input
12V/24V DC 8A max
Specs
Net Weight *
30.9 lbs (14 kg)
Dimension *
15.7 x 8.3 x 10.6 in (40 x 21 x 27 cm)
Charge Temperature
32 to 113°F ± 5°F (0 to 45°C ± 3°C)
Discharge Temperature
-4 to 113°F ± 5°F (-20 to 45°C ± 3°C)
Capacity
1260Wh
Cycle Life
800 Cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Full Recharge Time
1.6 Hours (AC) 13.5 Hours (12V Car Charger) 4-8 Hours (Using 4x 110W Solar Panels in parallel) 3.5-7 Hours (Using 3x 160W Solar Panels)
Charge Method
AC Wall Outlet, 12V/24V Car Charger, Solar Panel
AC Charge Input Power
X-Stream Charge 1200W Max
AC Charge Input Voltage
220-240Vac (50Hz/60Hz)
Solar Charge Input
400W 10-65V DC 10A max
Car Charger Input
12V/24V DC 8A max
AC Output (x2)
1800W (Surge 3300W) total, 230Vac (50Hz/60Hz)
USB-C Output (x2)
5V DC, 9V DC, 15V DC, 20V DC, 3A, 60W Max, per port
USB-A Output (x2)
5V DC,2.4A,12W Max, per port
USB-A Fast Charge (x2)
5V/2.4A,9V/2A,12V/1.5A 18W Max
Car Power Output (x1)
108.8W, 13.6V DC, 8A max
Cell Chemistry
Lithium-ion
Cell Type
18650
Shelf Life
1 year (after fully charging the device)
Testing and certification
UL CE FCC RoHS RCM PSE
Warranty
24 months
fwiw . . .
looks like APP is only availible on RIVER series,
and DELTA MAX & Pro.
Get power outage ready, go-off-grid and more with EcoFlow portable power stations & solar panels. Learn more.
us.ecoflow.com
