Colin123
Thanks to the posts here I have established that my solar panel has failed. It charges until it gets sunny then packs up. It’s a flexible 60w panel stuck on the pop top and charging 2x110 ah batteries through a MPPT Pro dual battery charger. It’s a Camperking conversion and although I’m not the original purchaser CK are looking to see if a warranty replacement is possible. Not unreasonably I’d need to pay a labour charge of course. Whilst it’s only 60w I have never had a problem with 12v power.
However, given the need for it to be replaced I’m considering a number of options.
- Replace with another 60w flexible that may fail again in a couple/few years … labour cost about £425.
- Replace with a larger panel 100w CK suggested as that’s the smallest they normally do … cost about £900.
- Replace with something like a 150w panel … probably rigid and fixed to the roof with mounting brackets. £??
My existing MPPT shouldn’t need to be replaced.
A couple of questions … is it easy enough to get the old panel off … it’s been bonded to the pop top with something. Having done that the replacement options … does something rigid in mounting brackets create any significant wind noise? Finally, the MPPT charges both leisure batteries as it has batt1 and batt2 output. Why could I not charge the 2 batteries in parallel as batt1 and then run a wire to the main van battery from batt2 to keep the van battery charged when the van is parked up for a couple of weeks awaiting its next outing?
I’m in Dorset just outside Poole so any recommendations for a fitter could be helpful!
Thanks, Colin
Thanks, Colin
