N NP01 Member 4 Sep 2024 #1 I've just noticed this hose hanging off can anyone enlighten me as to what it is ? VW T6 2016 Trendline. Many thanks Nathan
Dundee_Kev MOT Tester VIP Member T6 Guru 4 Sep 2024 #2 It's not a hose, it's the exhaust gas temperature sensor by the looks of it
Garyde Senior Member T6 Guru 4 Sep 2024 #3 Thats a sensor, if its the same as below it should have a brown connector. Would suggest its probably a Lambda sensor.
N NP01 Member 4 Sep 2024 #4 Dundee_Kev said: It's not a hose, it's the exhaust gas temperature sensor by the looks of it Click to expand... Oh so that could just be still attached and wires protected by rubber pipe Thankyou Garyde said: Thats a sensor, if its the same as below it should have a brown connector. Would suggest its probably a Lambda sensor. View attachment 257788 Click to expand... Thanks
Dundee_Kev MOT Tester VIP Member T6 Guru 4 Sep 2024 #5 NP01 said: Oh so that could just be still attached and wires protected by rubber pipe Thankyou Click to expand... Yeah, if you push the protection down you'll see the wire inside
