Any photos of -50mm or -45mm drops on 20’s?
G4GASSCOTLAND
I'm looking to lower my t6.1, looking at the eibach Racine 50mm or eibach so low 45mm. I've got new wheels to put on with 275/40/20 tyres, anyone got photos of either springs fitted and should I expect rubbing??
Hi there, Caution with both of those kit , with standard shocks the ride will definitely be sub optimal . the other issue is , how heavy is your van and what goes on in the rear , its highly likely to go lower than spec if the van is heavy
I would urge you to call us before doing anything as this could be the beginning of a nightmare for you .
Both the kits you mentioned are not on the Eibach web site and this means they arent really Eibach offerings , who knows what spec they were made to ?? and who designed them ,it wont be eibach they only do a 30 mm kit i think .
What is this set up are is it lowered on springs and if so by how much.
I have 275-40-20 myself and want to make the gap in wheel arch less like this
That looks like approx 40 mm lowering . shouldnt touch on those big tyres
Thanks for the reply. I’m trying to sort out a time I can actually call yourself to discuss options for me. Just very busy in work at moment and not driving home until after 17:30. Will try to make time this week one dinner if possible a
