I fitted a Westfalia removable towbar to the van last night and tried using it today with my twin axle trailer.
The ball is so high the front wheels are off the ground. It measures 470mm to the center of the ball. I searched what the standard ball height is and found EU legistation states center of the ball should be 350mm-420mm from the ground so mines 2" higher than it should be. I rang Westfalia and spoke to a guy called Fabio, he said thats the height it is, it doesnt matter how high it is in real life, its ok on paper. The bars can only be designed using the information supplied by VW on the mounting points and the ball height is determined by where VW tell them how far from the ground they are. It seems type approval is then given because on paper the the ball is in the right place, but is not even in the right place on paper....
Westfalia also say the center of the ball should be 450mm from the ground on this model which is still higher than the 420mm the legislation says it should be!
Fabio gave me some great advice though, can the trailer be redesigned!!!
The stupid thing is they make various other swan necks for different vehicles with lower balls in relation to the mount, but they cant sell me one because its not type approved for my bar.
Anyone know how Westfalia and VW can get type approval for a bar that, in there admission is not at the right height?
Anyone else had towbar height problems?
