@andys I had a courtesy T6 a while back and it allowed distance setting whilst moving, I'm guessing this is a different HW/SW, I think I took a scan of it so I'll double check to see what it had.
As far as I know ACC and braking use the same sensor so I assume (maybe wrongly) that it's the same sensor, if you scan @PukkaT6 van you can compare the HW number with your ACC module or if someone with an MY18 can send me their reg I will pull it up on etka and double check@Pauly from what I read tho, the 'emergency city breaking' is a laser sensor and the ACC is a radar, so completely different HW, maybe it wouldn't be too difficult to upgrade if the wires are there (CAN & Power)
Not sure on that, i have city braking and acc 130 on a single unit, we should compare part numbers from my scan.@Pauly from what I read tho, the 'emergency city breaking' is a laser sensor and the ACC is a radar, so completely different HW, maybe it wouldn't be too difficult to upgrade if the wires are there (CAN & Power)
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0210
Serial number: 27081604393274
Coding: 00005000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361_SK34.rod
VCID: 3666B25289630BF72B-8062
I'm going to take that back, just looked at this a bit more and the radar sensor on this MY18 matches the radar unit fitted in vehicles with ACC from the factory (compared it to @Loz van) so this certainly merits more digging as it may be possible to activate ACCIt means your front radar looks different from one in a vehicle factory fitted with ACC but more info required yet
