Hi all,
I am hoping you may be able to help, I have recently fitted the OEM spec DRL’s from van style to my T6 (standard headlamp).
Physical fitting has been fine and they work when the ignition is turned on,all spliced into the headlamp connector as per the booklet, however is have some issue.
1 - Bulb warning on dash, if I leave the van for a few days it sometimes clears but 20mins into a trip it’ll come on again…
2 - DRL’s don’t turn off when the headlights come on, they are supposed to however the lights don’t seem to respond to the “coding” instructions in the booklet.
3 - the fitting instructions mention the vehicle “may” require the fitting of a 5 position relay, however makes no reference to where or a wiring diagram!
Can anyone shed any light on the issue? Help us gratefully received!
