I’ll give that a go, thanksUsing a trim tool you need to carefully remove the facia that surrounds the head unit and has the middle vents incorporated into it - the head unit stays in place (it's pretty easy to remove). You should then (hopefully!) be able to get to the back of that section to disconnect the 12v socket and take it out
No chance, fascia off headunit out, no chance of getting to the wiring, it’s attached to other wiring tucked under the trim piece initially wanted to get off. I need to get access much lower down to get to the wires, and then find the connector.Using a trim tool you need to carefully remove the facia that surrounds the head unit and has the middle vents incorporated into it - the head unit stays in place (it's pretty easy to remove). You should then (hopefully!) be able to get to the back of that section to disconnect the 12v socket and take it out
NopeThink you have to push from the back while levering with tool at front or put finger in 12v hole and pull
Apologies for being dismissive, actually you were correct. The mistake I was making was trying to be careful. Once I lost my temper and swore and yanked at it, it did indeed come off, giving access to the plug very easily. Thank you.Think you have to push from the back while levering with tool at front or put finger in 12v hole and pull
Apologies if it was no help. Having done it myself and having to remove something fitted in that cubby, I was able to reach and it worked for me. I did say 'the head unit stays in place' you didn't actually need to take it all out. Getting the vent surround off is a 2-minute job with a trim tool and it helped me push that unit you needed to get through from the back. Reading your other comment and for reference, it wasn't just a "best guess", I kindly offered it up as it worked for me and for others too. Either way, glad you got it sorted.No chance, fascia off headunit out, no chance of getting to the wiring, it’s attached to other wiring tucked under the trim piece initially wanted to get off. I need to get access much lower down to get to the wires, and then find the connector.
Van X sell a gloss black infill for that hole. It has 3 cut outs for for varios switches/ 12 v sockets/ usb etc.What did you buy to replace the surround of the socket? Mine crumbled at the weekend and I've been looking for hours now! Can only find just the socket (no surround) or a complete unit for a T5 which says it's not compatible with a T6.
