Anyone up on t6 bcm
Not sure what you are up to, but perhaps this will be helpful.
Replacement BCM is the next step.
I think I have never seen physical failure of a BCM unit before.
Have you checked your local pricing options?
Are you considering new or second hand BCM?
If you go ahead with a D revision, you need to take into account the additional cost of getting your key fobs remote function paired.
7E0937090B and 7E0937090C have the same functionality as 7E0937090D and remote key fob can be paired with a VCDS.
Additionally, as I have mentioned before, the software on B and C can be updated to revision D and remote pairing method remains as it was originally.
I'm basicly going to to attempt 4wd dsg into a t5 .
Already find I need to modify rear mounting pi to and handbrake cables. Etc . But chap I bought it from said it was t6 ?
So I'm trying to confirm the modules and part list are all off t6. . Before I transplant the vechical loom into the vechical ? I can add the part numbers off modules if u possibly know
