HiHi does anyone run on 235/55 r18 instead of the usual 235/50 r18? Because they are 12.7mm more in diameter, I wonder if they look like swampies or whether the difference is not noticeable. I appreciate the speedo will under read by 3% but is the gearing noticeably higher? Cheers
Thanks. Ours is 204 DSG. I might just go for the Nokians Weatherproofs in the correct size but they’re £45 more a corner than the General Snow Grabbers that I fancied that only come in the 55 profile on r18. Also worried that the extra 12mm will get the Cali too close for comfort to 2m barriers.Hi
I don't run 235/55/18 but I do run 235/60/17 the same rolling radius. When my current tyres are warn out (Nokian weatherproofs), I'm fitting some 18" Amarok alloys with 235/55/18's (same tyres)
So having done 35k miles with 3% oversized tyres with a 204 BiTDI DSG 4mo., I have to say that yes I can tell a difference, but only when you floor the throttle waiting for it to change down. It's just a tad less urgent. But drivability wise it's fine. If you had a manual gear box, I think you would notice it less, as the change points are your decision.
The tyres look so much better imo, Its well worth it But you will need 25mm spacers all round if you are running VW Wheels to max the asthetics
I cannot tell how much I've moved backwards and forwards re full winters v all-season tyres. For a Van/Vel/Cali, I think premium all-season are the answer; Particularly if you use the vehicle predominantly in the UK, driving around today its 12c with us, and if it were to rain, I've read so many people think winters can be very poor in these circumstances.Thanks. Ours is 204 DSG. I might just go for the Nokians Weatherproofs in the correct size but they’re £45 more a corner than the General Snow Grabbers that I fancied that only come in the 55 profile on r18. Also worried that the extra 12mm will get the Cali too close for comfort to 2m barriers.
The Nokian weatherproof SUV 235/50/18 only have 101 load rating; thats no enough for a Cali I think.I cannot tell how much I've moved backwards and forwards re full winters v all-season tyres. For a Van/Vel/Cali, I think premium all-season are the answer; Particularly if you use the vehicle predominantly in the UK, driving around today its 12c with us, and if it were to rain, I've read so many people think winters can be very poor in these circumstances.
My Vel exec came with 20mm dynamic suspension (20mm lowered) so it starts out at 1950mm high; +13mm is still fine for me.
the 235/55/18 have 104 which is fine for all T6's
Here you go mate. 235/55/18 General Grabber AT3s on a 204 T32 DSGHi does anyone run on 235/55 r18 instead of the usual 235/50 r18? Because they are 12.7mm more in diameter, I wonder if they look like swampies or whether the difference is not noticeable. I appreciate the speedo will under read by 3% but is the gearing noticeably higher? Cheers
Thanks mate but yours are 255/45 r18 which are the size VW usually fit to r18 alloys and are the correct diameter. The ones I wanted were narrower and 14.5mm more diameter. Your wheels look like Assassins: v nice had those on my T5 kombiView attachment 34461 View attachment 34461 I'm running these if I can add to the post View attachment 34461
Yes they are cheersThanks mate but yours are 255/45 r18 which are the size VW usually fit to r18 alloys and are the correct diameter. The ones I wanted were narrower and 14.5mm more diameter. Your wheels look like Assassins: v nice had those on my T5 kombi
I go away a fair bit and come across all sorts of terrain.Here we are ...235/55/18 General Grabber AT3s on a 204 T32 DSGView attachment 34608
Doesn't look as aggressive off road as the GG AT3, and doesn't have the 3pmsf winter rating (I don't think);There is another tyre also in 235/55/18 AT
https://www.mytyres.co.uk/cgi-bin/r...MI_JbWlPvQ4wIVhbTtCh2yXgoBEAQYAiABEgL5rfD_BwE
Looks interesting
Hi Chris, I appreciate this is an old thread but I’ve just ordered x4 235 55 18 Michelin cross climates for my T6. Wondered how you found them?My mistake, I thought the Cali's had slightly higher rear axel (max) loads; although I guess you could easily accidentally overload the rear axel; in which case a bit of extra capacity would only help.
I have a set of Michelins CC SUV on order from my volvo xc40 245/45/20's (standard size for my xc40); they are expensive in that size; but I think they're my best bet.
Think i will stick with Nokians on the van; we'll see.
