For Sale Atera Casar XL (540L) roof box, textured lava grey, 082295
Dellmassive
VCDS User
Moderator
T6 Master
Atera Casar XL (540L) roof box, textured lava grey, 082295​
Only used/on the van once for summer camp - been in storage since then
still has two years guarantee on it.
looking for £350 collected.
this is the one and only time it got used. . .
1741082655873.png1741082709186.png1741082721525.png1741082676519.png1741082695646.png1741082665962.png
Roof bar compatibility​
Steel (22mm x 32mm) barsYes. fits bars up to 95mm wide x 38mm deep oval/wing bars or 95mm x 28mm rectangular bars
Aero barsYes. T-track adapters (available separately) are required for some Audi branded roof bars that are too deep for the Premium-Fit fittings
Min. distance between roof bars550mm
Max. distance between roof bars950mm
Box features / capacity​
Box opens fromBoth sides
Maximum loading capacity75kg
Volume540 litres
Maximum number of skis7-8. (max 210cm)
Length (internal)2100mm
Width (internal)850mm
General information​
BrandAtera
Guarantee5 years
Length2150mm
Width900mm
Height430mm
Weight20.5kg
ColourGrey. (dark grey)
FinishMatt
The Atera Casar has a purposeful, fine-looking lid design that maximises the internal space while still providing the rigidity and stability required. The roof box base includes recesses which bring the whole box closer to the car roof; these recesses are long enough to accommodate widely-spaced roof bars or prominent rear tailgate spoilers; in other words, we expect the Casar to be able to be fitted to all cars.
Dual-side opening, and claw-style fittings: As you'd expect for a box in this price range, it includes dual-side opening so you can mount it on the left or the right of the car roof for easier fitting and easier access (you can of course position it in the middle of the roof if you prefer!) Its low-profile Premium-Fit claw style roof bar fittings include a torque limiter, so you can't over-tighten them. Claw-style fittings will limit the positioning of the roof box if they clash with the roof bar mountings, but the Premium-Fit system is very easily replaced with T-track adapters (listed below), allowing you to position the box wherever you want on a pair of aluminium T-track roof bars.
The SafeGuard System: The Casar includes a very clever new box opening and closing system, called SafeGuard:
  • Box opening: When you pull the metal handle it lifts the lid just enough to separate the locking components in the lid and base, and to 'break the seal', so opening the lid is particularly easy to do, jerk free and smooth.
  • Box closing: It's a 'Just pull to shut' system, with 3 point central locking. Pull on the lid until all 3 locks engage - you'll hear a click and the opening handle will have snapped shut into its housing; you'll then know it's properly closed.
  • Locking is separate from closing: You don't need to use the key to open or close the box - you lock it only when you want to lock it, usually when leaving the box unattended. This can make for a better all-round experience, especially if the box key is on the car key set. For example, you may not wish to lock the box while you're loading it (but you still want to shut it, if it's windy or raining) or if you're travelling around a ski resort, or from a campsite to the beach.
Other features:
  • This box has a textured lava grey lid on a matt-black base.
  • Externally, 215cm x 90cm x 43cm - space for one bike carrier on 120cm or 122cm aluminium roof bars
  • Internally, 210cm x 85cm x 42cm
  • The empty box weighs 20.5kg, and it's certified to carry a maximum load of 75kg. You should note your vehicle's maximum roof loading limit, and the weight of the roof bars and roof box, before working out what maximum weight you should carry.
  • Premium-Fit box to bar fittings are suitable for almost all roof bars - they'll fit 95mm wide x 38mm deep oval or wing-shaped bars, or 95mm x 28mm rectangular bars). Note that Premium-Fit will not fit Thule ProBars. T-track adapters (listed below) will provide more flexibility about where the box can be placed on the roof bars, and may be required if your roof bars are unusually deep. Note that Premium-Fit include a locking device so they can't be loosened accidentally.
  • Internal luggage straps are included to help secure your gear inside the box; they should be used, especially if carrying narrow and heavy items such as skis.
  • Atera Casar boxes have been thoroughly tested by the German TÜV to the latest standards, including "City Crash testing".
  • 5 year guarantee
Atera is the leading German car rack systems brand, although they have their boxes made for them by Hapro in Holland. Atera's commitment to engineering excellence and quality is demonstrated by the fact that the majority of their business is with the Original Equipment market, i.e. direct to the car manufacturers, where major customers include Audi, BMW, Daewoo, Chrysler, Fiat, Honda, Mitsubishi, Mercedes, Opel, Subaru, Suzuki, Vauxhall and Volkswagen.
Summary: A top-notch box with superb build quality; it's a pleasure to use. The materials quality is up there with the KAMEI Corvara S (and better than the Thule Motion XT); we're pleased to give it an overall five star rating.
