I’m having some teething issue with my drive away awning using a kadar strip and want to make sure I’m doing it right and not missing something simple. I have the following issues:
1. Alignment: the kadar only gives about an extra inch of alignment meaning you need to line up pretty much perfectly to get the awning in and not been drooping/sagging. Is that really the design? If so is it not just easier not to use the kadar and one person just thread through the awning directly onto the rail whilst the other drives slowly forward.
2. The plastic figure 8 adapters seem pretty weak. 2 have already broken. Is there a stronger replacement, was thinking metal but worried about the paintwork.
3. Drips: as the figures of 8 can only be butted up to each other naturally water drips through. Is there a solution to stop this? When not using the drive away adapter there isn’t any leakage.
Any help much appreciated.
