The vent in the passenger footwell should be pulling in cold air to be heated in the autoterm and then come out of the rear vent so it recirculates the air and hopefully warms it quicker otherwise I’m not sure why you’d have a vent in the footwell
Check that the duct is connected to the rear of the vent as the only way that it can blow air is if it is disconnected. Unless you are confusing suck with blow due to the air movement.
I would do as the display says, it couldn't be plainer.
Possibly no fuel or a blockage.
Or, if the installer has connected the fuel supply to the return to the tank you have drained the engine fuel line. ( after long running without engine running )
