Well pleased with this…. Motto of the story is….be brave, loosen the grill by removing the four plastic pins under the bonnet overhang on the grill, use a credit card that doesn’t matter if you knacker it up a bit! Slide credit card in between trim and the grill and then edge in trim removal tool,,, bit at a time and wiggle clips from rear of silver trim. Some break off but they were going in bin anyway.! There is some horrible plastic crunching sounds as you do it but as long as it’s the trim being removed and not the grill…that’s ok. Bottom ones came off with no bother at all….new ones clipped in as if they were OEM parts. Job done! Now…looking at the photo…She needs a good wash this weekend
