Sold Axe EX30 20” wheels & tyres £550
Mine is a T32 and how it has been explained to me is 850 kgs per wheel so you times that by 4 to get 3400 kgs. I’m no expert but that is how I understand it ? There might be guys on here that know more ??
850kg is a enough for a T28 isn’t it ??
850 x2 = 1700kg. Provided both your axle weights are under this, then yes.
Check that the tyres also exceed this, too.
I’m no expert but that is how I understand it?
No, it’s per axle. One will bear more weight than the other, which may mean that you’re over on one - or even both - axles with wheel load-ratings.
So is 850kg ok for a t28 ???
Yes. You should have a label under the bonnet that shows your axle weights. As long as they are below 1700kg, which a T28 is, then you’ll be fine with 850kg rated wheels.
