Found Banded steels
GONA66
CARAVELLE
Hi Guys, looking for a set of Banded Amoraks or Rangerovers or even the JBW Pepperpots . Staggered 8.5" fronts 9" rears or 9" front 9.5" rears RR. Need to fit the Caravelle sliding door set up.
Colour unimportant as i will re-do. Prefer without tyres.
Cheers.
Reactions: DWS
Cheers.
PM incoming
im convinced i need steels for a t32 on solows,
Bare in mind that if you want the Solows very low, like mine below, and you run 17, 18 or 19" wheels with lower profiles, it will scrub the ground quite a lot.
I've run every size steel on mine, ranging from 35 profiles on my 19s, right up to 50s on my 17s, and every set scrubbed staggered speed humps or aggressive dips in the road. It also makes parking on a driveway that you go up and drop kerb, to go down a drive, impossible because it just bottoms out.
This will scar up your underside plastics, exhaust and in worst cases like mine, wear through your Adblue tank which I had to replace and cost over £1000 from VW because all the sensors are housed in the tank.
I'm now running 20"steels on 35 profiles and it's stopped all of the above, but still looks good and drives totally fine.
Yes, I am low, which you might not be going as extreme, but Solows are very low once you start winding them down, and bare in mind I'm only about half way down on mine.
PS, these steels are for sale on the sales page if they float your boat.
Thanks for the info some food for thought lol, was gonna keep them on highest setting but don't have a clue which way to go regarding wheels and tyres, would like to keep the load rating if possible, BTW the wheels look great.
