Barn Door cargo net??
hatjoepeg
Anyone come up with a good way of securing ’stuff’ with a cargo net between the back of the bed and doors when travelling.
I was thinking of a few lashing points and then a net so you can still get into the cupboards but suspend stuff pressed against the seat back?
got a net arriving from e bay today but inspiration or photos welcomed
Cargo net permanently attached at 2 points under the bed, and karabiners to attach to 2 loops of cord fixed on the top.
It doesn’t look wide enough, but it works well.
Pete
Is your van carpeted ? In the door shut of the rear there are already holes I popped some lashing points in with rivnuts
Pete
Done very similar to the frame too didn’t fancy the Cadac smacking me upside the head under braking
it was converted when I got it so everything is covered up, pretty sure we can lash something up though
If you feel inside the door shut about 50cm up either side there is a divet in the frame about 4cm in behind the rubber seal in the middle of the divet is a hole you’ll feel it through the carpet
I got one of these yep it’s a bit bright but strong and great price
lolly-U Garden Climbing Frame Net for Kids Durable Nylon Rainbow Ribbon Netting Rope Outdoor Physical Training Climbing Net for Daily Sports and Entertainment 145X185cm lolly-U Garden Climbing Frame Net for Kids Durable Nylon Rainbow Ribbon Netting Rope Outdoor Physical Training Climbing Net for Daily Sports and Entertainment 145X185cm: Amazon.co.uk: Sports & Outdoors
£8.99 on E Bay
Job done (between showers)!
Hi,
What screws did you use to attach these? I've got a similar kit, but don't fancy relying on the adhesive strip, and the supplied screws look too long - My cabinets come past the rear pillar.
I just used the screws they came with straight into the lining material. They have been well stretched and show no signs of coming off yet!!
£8.99 on E Bay
I did the exactly the same, bought a net off Fleabay and used self tapping screws (drilled a pilot hole first) to secure the mounting points (also off eBay) through the carpet lining straight into the steel body work.
