Hi all,
trying to buy electrics and i have tried searching through forum and Dellmassive's guides but i cant see much info in what im looking for specifically.
Originally i was going to go with battery under the drivers seat as most have advised, especially as having a swivel bench seat. The problem is i dont have space to have the inverter in there aswell as i wish to have as large a lithium battery as possible under the seat so that i can run a 2000w inverter
Is it possible to have the inverter close to the LB under the drivers seat but not actually under it? could i have the inverter in the side behind the panel or perhaps on the side of the kitchen unit that faces the rear of drivers seat?
if not possible then i will default to having 2 x lithiums in the rear and a longer thicker cable form main battery to LB and most of the hardware at the rear also
many thanks in advance
kindest regards
kindest regards
