I'm led to understand that the battery doesn't charge from ticking over on the drive because the van uses regenerative braking energy to charge it. That's right yes?
I haven't used my van much over the past 18 months and predictably, the battery tends to be quite down on its SOC. (I base this on the speed the starter motor turns the engine rather than through a meter). I can also tell when the battery is sufficiently charged because my stop/start starts working!
Anyway, I decided to top the battery up by giving it a run down the motorway. Despite a couple of hundred miles the stop/start still wasn't working but the battery turned the van over quickly enough so I was happy enough.
The second time I decided to top the battery up I drove around my area which is quite hilly and requires much more braking than on a motorway. After a relatively short period of time the stop/start began to work and the battery was therefore charged. Total distance around 30 miles.
Is it correct to assume that, in order to charge the battery the quickest way, I should find a steep hill and to ride the brakes down it as much as possible rather than say chugging along a motorway/dual carriageway?
