Evening all,
I am hoping that someone can offer some help with my battery issue.
Over the past few days my battery has been draining overnight hence when I try to start the van I need to use my Noco Booster to get it started,
I have used my Noco Genius10 to charge the battery once disconnected from the van, when this was completed the battery voltage was 12.88. I then connected it up to the van and the van started, the voltage on starting dropped to 11.46v, when the van was running the voltage increased to 13.15v.
Once the van was shutdown I could not start the van again with the voltage being 11.29v.
Chris @Dav-Tec has been trying to help me solve the issue however we have hit a dead end, Chris said to post on the forum for any advise you can offer.
The battery is Bosch unit which is only a few months old.
I have attached the scan I did on my van post the van starting up.
Pete
Pete
