The important thing to remember is to not get fixated on the % that battery monitors can can show.
due to the nature of the start/stop system the readings fluctuate wildly . .
also the Firmware inside these devices is set for a wide selection of batteries - built mostly Standard Lead Acid battery's (which will slue the readouts when on a AGM battery as they have higher resting voltage)
what is important is the history logging - Which the CTEK and BM2 do.
in this example you can see a very low battery being charged (mains charger) . . it starts LOW at about 10.2v and gets charged to 13.2v in the end.
in this example you can can see the engine and alternator charging the battery when charging . . .
in this example you can see a Lifepo4 being rapidly discharged by a test. . . .
so using the history log you can see the effect of the change in voltage over time . . so whether the battery is going flat or you have charging issues etc these chart will give you an indication on whats going on.
Having said all that they are still very usefully in standard mode . . .
for a standard T6 we have notice that above 12.0v is ok - normal. (voltage reading at rest with van off)
11.9v is low and the van will need charging. (voltage reading at rest with van off)
if you get more than one BM2 - say one on the starter and one on the AUX battery . . .
you can use the BM3 APP with can display up to 4x battery's simultaneously . .
Also the BM2 is the closest to the CTEK is looks and usage - so it will be familiar to you.
Bm2 :
Battery Monitor BM2 device for car's 12V Battery/leisure battery tester Compatible with Android iOS and Ipad with bluetooth 4.0 and above.: Amazon.co.uk: Car & Motorbike
I've tried all the others . . .
The BM2 is the currently best, most accurate easy to use, low power, cheapest voltage datalogger available - IHMO
its been around for a few years now . . . so im expecting copy's / cloans and a possible new version with more features?
only time will tell.
