Tuesday,04,March,2025,10:30:38:24488
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.0.2 (x64) HEX-V2 CB: 0.4660.4
Data version: 20250228 DS364.1
www.Ross-Tech.com
VIN: WV1ZZZ7HZJH134300 License Plate: GF18UZM
Mileage: 253120km-157281mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 56 61 0B
VIN: WV1ZZZ7HZJH134300 Mileage: 253120km-157281miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (2D2D2-CXGA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 JS HW: 04L 907 445
Component: R4 2.0l TDI H02 4044
Revision: 23002001
Coding: 00114014430401090000
Shop #: WSC 02762 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056JS 004004
ROD: EV_ECM20TDI03004L906056JS_004.rod
VCID: 074B97751FA8CEB2CEB-8052
VINID: 9E606AAAA1D8A9A6010C40C000460D17F7
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 60438000000740
Coding: 517E4098256584828A780276A48221E679F100
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB4F9507F84672B6B-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 29011813470065
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F29140728F7AFDD-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AK HW: 7E0 907 047 AK
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis_VN75.rod
VCID: 73B3D3A57B30D212823-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Component: BCM PQ25 Max4 H82 0752
Revision: B9082001 Serial number: 4000 037180296
Coding: E0A439380A212011002809342C2B84DC0F0070FF60464D70330400BB0840
Shop #: WSC 02762 534 156453
VCID: 2B030BC5E300CAD20A3-807E
Subsystem 1 - Part No SW: 7E0 959 801 R HW: 7E0 959 801 R Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 005 0653
Serial number: KU0KU007021880382056
Coding: 1400B1
Subsystem 2 - Part No SW: 7E0 959 802 Q HW: 7E0 959 802 Q Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 004 0653
Serial number: KU0KU005021880361125
Coding: 0400A1
Subsystem 3 - Part No SW: 2H0 959 442 HW: 2H0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 39180000826340058201
Coding: A4FFFF
1 Fault Found:
00975 - Heated Rear Window (Z1)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 169
Mileage: 253112 km
Time Indication: 0
Date: 2019.07.25.
Time: 16:51:44
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231801701002
Coding: 00800D
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BFD9AD012CE00270F-8024
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 0702180442AE37 Dataset Number: 7E0114v____ 0009
Coding: 00004000FE1779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 36352AB128C2873A65D-8062
6 Faults Found:
1380 - Internal Fault
B200F F0 [00001000] - -
[FAULT_ADC_VZ_BELOW_RADAR_OPERATION_LIMIT]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 252421 km
Date: 2025.02.14.
Time: 08:16:59
Control Module temperature: 9 C
Voltage terminal 15: 6.9 V
Vehicle speed: 0.07 m/s
Acceleration: -0.32 m/s
1130 - Sensor for Automatic Distance Control
C110B F0 [00001000] - Limited Visibility
[FAULT_SENSOR_NO_FREE_SIGHT]
Freeze Frame:
Fault Priority: 9
Fault Frequency: 2
Reset counter: 194
Voltage terminal 15: 11.5 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s
1132 - Sensor for Automatic Distance Control
[FAULT_SYSTEM_DISTURBED]
Freeze Frame:
Fault Priority: 9
Fault Frequency: 5
Reset counter: 194
Mileage: 251135 km
Date: 2024.12.25.
Time: 21:18:18
Control Module temperature: 20 C
Voltage terminal 15: 14.5 V
Vehicle speed: 5.19 m/s
Acceleration: -1.27 m/s
1131 - Sensor for Automatic Distance Control
[FAULT_SYSTEM_NO_FREE_SIGHT]
Freeze Frame:
Fault Priority: 9
Fault Frequency: 2
Reset counter: 194
1542 - Sensor for Automatic Distance Control
[FAULT_SENSOR_BLIND]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 194
Mileage: 251135 km
Date: 2024.12.25.
Time: 21:18:18
1545 - Sensor for Automatic Distance Control
[FAULT_SYSTEM_BLIND]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 194
Mileage: 251135 km
Date: 2024.12.25.
Time: 21:18:18
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 J HW: 7E0 959 655 J
Component: VW10Airbag021 010 0018
Revision: -------- Serial number: 003EK000C4DN Dataset Number: 7E0003V____ 0905
Coding: 000000000000000000000000000000003231
Shop #: WSC 02164 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3D27359D0DF45462A47-8068
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1107
Serial number: 00000000000000
Coding: 450B000300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
VCID: 3A2D3E811CDA635A815-806E
1 Fault Found:
10486016 - Control module
B2001 00 [00001001] - Incorrect software version
[BAP: Steuerger t falsche Softwareversion]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 84
Mileage: 250781 km
Date: 2024.10.01.
Time: 16:09:58
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Component: GW-K-CAN TP20 H82 0752
Revision: B9082001
Coding: 042303
VCID: 6889B4C9327621CA271-803C
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 210
Mileage: 253112 km
Time Indication: 0
Date: 2019.07.25.
Time: 17:04:42
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1107
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: 6A8DCEC12CFA13DA315-803E
Address 56: Radio
Cannot be reached
Address 61: Battery Regul.
Cannot be reached
End----(Elapsed Time: 01:16, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
------------------------------9 Faults Found----------------
