K K beads New Member 20 Feb 2021 #1 Its Ok I've found it. couldnt delete this so I've edited it. Thanks anyway Last edited: 20 Feb 2021
Garny999 Senior Member T6 Guru 20 Feb 2021 #2 K beads said: Its Ok I've found it. couldnt delete this so I've edited it. Thanks anyway Click to expand... Share?
K K beads New Member 23 Feb 2021 #3 Turns out it is in the same position but theres a fuse board in front of it. Also there are now 3 plugs in the back of the BCM not 2 like the T6
Garny999 Senior Member T6 Guru 23 Feb 2021 #4 K beads said: Turns out it is in the same position but theres a fuse board in front of it. Also there are now 3 plugs in the back of the BCM not 2 like the T6 Click to expand... Brilliant, thanks for the info.
T6Jay Senior Member VIP Member T6 Guru 3 Aug 2021 #5 Could anyone complete this thread by actually posting the location (on the T6.1 if possible)? I need to get to the wire for the lock/unlock pushbutton mod, I assume the BCM is where I will find it. TIA
Loz Senior Member Admin Moderator VIP Member 4 Aug 2021 #6 As above, it’s behind the fuse panel below the headlight switch.
