BCM upgrade for ccs on T5 GP
tommo
Hi guys,
I know it's been brought up a thousand times but even using the search function I haven't solved anything, I still have a lot of doubts...
i need to replace a BCM last numbers 086 in a T5 GP model with a newer one 087 version to install ccs on a 140hp engine
after reading all the various posts I learned the following steps i need to do
1 - read from old bcm long code from address 9, 19, (and 61 if battery regulator is present)
2 - backup all the adaptations with the specific function in VCDS
3 - read and save the Gateway installation lists.
after that, install the 087 BCM (used or new is the same)
1 - write all the long codes read by the old bcm
2 - write all the adaptations
3 - write the installation list on the Gateway...
that's ALL???
or i need to do some other coding or something else?
thanks to anyone can help me.
cheers
I would expect also the keyfobs (central locking) need to be adopted by new BCM.
thank you very much!
Reactions: mmi
