By having BCM PQ25 Max4 H81 0744 onboard you have already almost all possible add ons included in your CAN Gateway "Installation List".if there is no benefit then I give up
thanks for your quick replies
I have a lot to read and learn on the forum
gerry
I have an Euro 5 model van, which I believe would not allow me to retro fit the direct TPMS, which I would like. Do you know which BCM I would be able to fit to allow this?By having BCM PQ25 Max4 H81 0744 onboard you have already almost all possible add ons included in your CAN Gateway "Installation List".
Things like: Electric Tailgate, Direct TPMS and so on .
So happy retrofitting
What's your BCM version?I have an Euro 5 model van, which I believe would not allow me to retro fit the direct TPMS, which I would like. Do you know which BCM I would be able to fit to allow this?
Its an 16 plate early T6.What's your BCM version?
Engine type has nothing to do with DTPMS
VCDSIts an 16 plate early T6.
Is there any way to check the BCM version without getting the trim off and physically having a look?
Thought that might be the answer. OK will have a look when I get a bit more time. ThanksVCDS
I forgot about very obvious one, the remote key fob programming.1. Capture and save your BCM coding and adaptation map.
2. Physical BCM replacement.
3. Restore coding and adaptations.
With the second hand unit there is one risky element. If you had DRIVER FATIGUE onboard ( in your BCM/CAN gateway) and it is not implemented in the replacement unit you need to add step number 4(upload parametrization file).
4. Fatigue Detection
A bit curious here. Could you please post full BCM data (including submodules) + vehicle's VIN (just strip off the last 5 digits). The above actually doesn't have actual software identifier nor hardware number - something like this "Part No SW: 7E0 937 090 X HW: 7E0 937 090 X". Of course I don't mind to see have even the full scan - for my "collection" for future reference.HELLO
I have a BCM PQ25 Max4 H81 0744
it is possible to change it by a
bcm pq25 max4 h82 0752
and what would be the advantage?
thank you
gerry
