Hi everyone, thought I’d do a post on my current findings.
2019 MAN TGE 2.0 bi-turbo 180bhp. The vehicle was misfiring up to around 1600rpm. After this it seemed to run fine.
The below video has a description of what’s been done so far, I’ve also fitted a pressure regulating valve with no improvement.
I’m on the fence whether to do a compression test now as I know cyd 1 will be significantly lower than the other 3 due to the lesser stroke meaning less travel to compress the air fuel mixture. Cylinders 2 and 3 are identical heights (cylinders 1 + 4 and 2 + 3 are paired in travel through the combustion cycle (Otto Cycle which refers to the characteristics of a gas when compressed - suck, squeeze, bang, blow).
I have yet to view the bores and the vehicle is not noticeably losing coolant.
Hopefully this’ll shed some light on the internal workings and document further findings, processes and fix for this issue.
This engine and gearbox have to be removed to strip and rebuild due to it being a rear wheel drive.
Cheers, Josh/JF Werkstatt.
