Additive for what? Unless you have a specific reason for using it, it’s snake oil.Does any have any recommendations for a good addditive I can use? Preferably one that isn’t difficult and readily accessible
David, how do you measure/apply dosage for this product? Do they supply a small measuring container and do you need a funnel to get it into the tank?Im a fan of millers ecomax diesel. I buy it in 5L bulk. In my head it turns normal fuel into premium for a not so premium price. At approx £1 a tank if it helps the engine and exhaust in the long run then worth it in my opinion.
Usually buy it from opie oils.
I bought this dosing bottle, fits well in passenger door card pocketDavid, how do you measure/apply dosage for this product? Do they supply a small measuring container and do you need a funnel to get it into the tank?
Any kind of funnel is kind of a no-no, the funnel will just smell in the van and contaminate everything. At least you would need a closed container to store the funnel in and still your fingers would smell of diesel after every fillup.do you need a funnel to get it into the tank?
The millers 500ml bottle is designed so you squeeze the bottle and it dispenses the measured amount of your choosing into the top of the bottle. You then just pour that amount into your tank.David, how do you measure/apply dosage for this product? Do they supply a small measuring container and do you need a funnel to get it into the tank?
You are not wrong, it’s easy to pour too much as Stihl is not a dosing bottle as such. RL-2 I’m using has rather liberal dosing instructions though: one 15oz bottle treats 300 gallons in regular maintenance or 100 gallons in strong cleaning so I can’t imagine an occasional overpour having too much effect on anything.I looked the Stihl one but wasn't sure if when you tipped it up there was a risk of pouring the whole lot in. @n10n could confirm? as lets be honest the Stihl one looks cooler...
if its anything like millers in a white semi translucent bottle it looks like someone was caught short! I have written on the bottle in sharpie just to clarify...You are not wrong, it’s easy to pour too much as Stihl is not a dosing bottle as such. RL-2 I’m using has rather liberal dosing instructions though: one 15oz bottle treats 300 gallons in regular maintenance or 100 gallons in strong cleaning so I can’t imagine an occasional overpour having too much effect on anything.
So, I premix little bit over 1dL of RL-2 to 9dL of diesel in the Stihl bottle. Then I aim to put 2dL of the premix into tank before filling, I usually fill about 57-60L. This way premixed Stihl bottle lasts 5 fills (reasonable range) before I have to prepare another premix.
And I can assure you Stihl does not look that cool filled halfway with diesel
