I'm currently routing some wires up to the overhead cubby hole area as I'm going to mount some switches up there.
One from under the drivers seat and 4 or 5 from behind the drivers seat (fuse box/relays are mounted at forward end of kitchen unit, directly behind the drivers seat).
I've took the dash end plastic and A pillar plastic/grab handle off then ran a couple of the wires in over the headlining with some draw wires. Before I pull them all through is this the best route as they will have to run across the floor/sidestep at some point (there isn't any factory stuff going this way), then up the wheel arch? Would it be better to run them all up the B pillar and over the drivers door maybe?
Seat and base etc are all out at the minute as I'm re-wiring some of my 12v leisure stuff, so no hardship to take them across the floor, just don't want them to get damaged.
I'm going to fabric tape all the wiring so it look a little more factory and prevent any chaffing.
Cheers!
Cheers!
