As mentioned in the post, what would be the best stuff to stick onto my load area floor so that the factory rubber mat will still fit on top of afterwards. I have lined all the rest of the rear with 2mm Silent coat and Dodo mat foil backed foam roll ( about 6mm I think) but I fear that this will be too thick to use on the floor and refit the rubber mat afterwards. I could just fit 2mm Silentcoat if that would do the job. I see from other threads that the Dodo Deadn Duo rubber mat has been used but this is 6.8mm thick and again I am not sure if my factory rubber mat will fit back on top. Any advice would be gladly received before I buy the wrong stuff.
