Tickz
CCTV Tech’
Hi All
i have a t6 t30 150 dsg highline kombi that i use for work. i had it lowered a using b14 kit, all professionally installed back in early 2018. In jan 2019 it was noticed that the rear springs had 'snapped'- lowest coil on the rears had snapped. I heard a big clunk after going over one of those little rubberised triangular speed bumps you get around (not at speed, im careful with those vicious little things). I had it diagnosed by the company that fitted them and ordered 2 rear springs (something like £250). This time the rears were raised by 10mm.
Now I have noticed that the rear left hand size has dropped and noticed a drop to the left, I've checked visually and it appears to have happened again.
It drives fine and there is no clunking or banging from it but obviously need to get sorted asap.
With regard to weight in the back, i dont believe its nowhere near capacity, i would estimate around 200 kilos or so i work in electronics my main toolbox is 40kgs and is by far the heaviest thing.
After the 1st break the company who fitted them contacted bilstein and asked if under warrantee etc, cant remember the details but they said no, so I just ordered a new set of rear springs and put it down to those bloody speedhumps-needed the van asap for work, basically sucked it up.
Now with it happening again, my question to you good people is..
Anyone have any similar issues? and any success for getting them replaced by bilstein??
And also can I replace the rear springs only with another brand?? (H&R,Eibach- I had 40mm lowering springs on my T5 before and had no such issues)
Thanks for taking time to read and thanks
I have hopefully attached a photo of the original pair of rear springs that you can see snapped on the lowest coil
