I have a T5.1, currently on standard springs all round. Because I often have up to 400kg in the back I'm about to fit a pair of sportline springs at the front to help level out the van, so it is rarely lower at the back than the front.
I also need new dampers at the rear, so thought it would be a good opportunity to fit a new set all round. I'm considering Bilstein B8s for the front and B6s for the rear. However one supplier has advised fitting B8s all round, despite the fact that the B6 damper is designed to be used in conjunction with a standard height spring, not the B8. When I queried this they didn't really give me an answer. As far as I am aware, the B6 and B8 are exactly the same in terms of damping set up, its just one is slightly taller than the other. Am I missing something?
Any advice much appreciated
