Bola Csr 19"
Donk
Now dormant
VCDS User
Morning people. About to order some Bola CSR wheels in 19"x8.5" flavour. I've checked the willtheyfitsite and still tossing up between ET45 or ET40. I was going to order ET40 - anyone able to assist with what would be best?
I'm running 20x8.5 et35 all round so I'm suggesting et40 you may then want to run a spacer on the rear. I'm running a 12mm spacer on the rear of mine
Hi I’ve just dropped you a message.
19” x 8.5 on the front
19”x 9.5 on the back
In the photos I haven’t used any wheel spacers just to give you an idea on the look.
Jack
Sorry mate, missed that.
I ran 19" 8.5" ET45 but out of the two choices, i'd now opt for ET40, and even that wouldn't be enough for me, so maybe some spacers, depending on your suspension and preferred style.
I'd initially opt for the ET40 and see if they are how you want visually. If you feel they need to bulk out towards the arch more, spacers are the only option on those offsets.
Hmmmm. I think you’re right. I think I’ll probably do 40’s get them through Tamar Wheels I think.
