Any recommendations on disc and pad replacements and costs? Looked on Vw commercial and its £680 for discs and pads to front and rear. Wondered if anyone had used an alternative either high street kind of place or anyone in Cornwall? Thanks
Had a quick search and couldn't find this information so thought I would post it up!
Just had the first major service and was quoted £380 plus VAT from the dealers to replace the front and rear pads. Local indy is doing them for £175 plus VAT.
Cheapest EBC Ultimax pads are around £70-£80 a set (depending on whether you've got big front brakes or not)
I prefer Greenstuff, a little more expensive.
If you have the most basic tool kit there's no reason you can't change pads yourself and save £100
Service Parts List - What Goes Where - Here is a Basic list for all Parts required for Servicing which will be updated moving forwards: Brakes: Pads: 308mm F Pagid Brake Pad (Front Axle) Product Code: 101441298 340mm F Pagid Pagid Brake Pad (Front Axle)Product Code: 101441868 340mm F Brembo...
