Brake light flashing and Hazzard warning lights under braking
RayC
Tyre testing and development
VCDS User
Hi Guys
its possible to tick boxes in 09 Central electronics to make the brake light flash under hard ABS braking and the hazard lights come on when you stop (they go off again when you move away)
good on motorway
I can post a scan later if needed van is not here right now but I'm sure some of you can find it
its also possible to active bulb checking etc
Have you tested it yet to see if it works ?
I enabled this on mine but not tried it out yet
I thought hazards flashing when braking hard was standard .
yes works on mine and on T5 and Amarok
Done this same tweak on mine. Oddly enough i’ve never seen whether it works or not!
Appreciate this is an old thread but does anyone have the full adaptations required for Central Electronics?
Hi Guys
good on motorway
Is this on the t6 only or does this work for the T6.1 also?
Not tried but I would think if the option is there it will work.
