Broken barn door glass
Wholigan
So, faffing about in the garden I notice a pile of rubbish dropped behind my van. Go to have look and it's not rubbish, it's a pile of glass and there's a big hole in the nearside barn door window. It looks like it's been punched out from the inside. I know it was intact earlier and either my partner or I had been close by all morning. Any ideas what might have caused it to shatter?
That's nuts....
Nothing inside the van?
OEM.windows or aftermarket?
Im thinking internal stress in the glass?..... Was it in the sun.? Etc etc etc.
It’s most strange how as you have mentioned the glass appears to have been smashed out the way from inside.
My thoughts are it some how was under tension and broke it’s self.
Unless you live near that escaped raccoon? and he was hiding in your van and broke his way out. :p
Funny that. Went out to the van this afternoon and found a big crack in the windscreen. Wasn't there last time I used it.....
Any feather marks around the hole - thinking bird strike.
That was one of my thoughts but there’s no feathers and all the broken glass was outside the vehicle. Not in the sun (this is England!) but one of my neighbours suggested thermal stress combined with a defect in the toughened glass
In a previous life was trained to get through various types of glass, ( and no I wasn’t a burglar before some one suggests such a thing) and it is surprising how little force of the wrong kind can shatter toughened glass, if it has been a point of impact the shatter pattern sometimes reveals where it was struck but not enough in the photo to see that. The damage can be initiated some time before the glass actually breaks.Defect or thermal stress can also break the glass and the window shows a fracture line kind of following the frame which could have resulted from thermal stress.
Both top and bottom righthand corners of the window appear damaged - as this is where the glass is at its weakest, that's where I suspect an impact has occurred. Have you recently p!ssed off a neighbour that access to an air pistol? :whistle:
Difficult to fire an air pistol from under the patio...
That's nuts....
What happens is this: the glass gets a bit bigger when it shatters because there is a space (air gap) in all the cracks. It is fixed to the door all round the edge, and is curved outwards. Hence the center of the sheet is forced outwards on the convex side and bits drop out this relieves the stress so the rest stays in place. The actual origin of the failure may never be evident. But likely a stress issue such as a sudden change in temperature or a minor impact.
I have seen a rear screen on a car shatter in the summer when it was very hot, quite a strange thing to see first hand, after the initial blowout small sections kept going off like popcorn.
This just happened on my t5 today - exactly the same. Trade Glass UK. They are sending me a new one tomorrow hopefully - it was only installed a month ago. Today was the hottest so far this year, my sliding door was open at the time so it was not caused by a high temp inside the van. Must be the heating of the glass/metal direct from the sun. I was in the garden when I heard a loud pop, so I went to the van to find glass on the driveway, sprayed as far as 3 meters away, I then saw this huge hole where the window had literally exploded outwards. I’m just glad no one was behind the van at the time.
Yep, exactly the same as mine. The guy who came out and fitted my new glass suggested it was thermal but it did cross my mind that I have a towbar mounted bike rack and it's possible that the handlebars of the bike nearest to the back of the van could bang on the glass if there's a serious bump in the road.
Hope you had an easier experience getting the glass replaced - I had to go through Glassline and the experience was horrendous starting with the contact centre not being able to grasp a) it was a van, and b) there are two windows in the back so they gave up and ordered a new passenger door glass.
