Brown connector identification [Solved]
eden warren
Hi
Can anybody tell what this Brown connector is for and where it should be plugged in?
Thanks Eden
Which engine do you have? is that the corner of the charge cooler? so a 204?
I believe it's the connector for the variable water pump, have you had a water pump changed as part of the cambelt change? if so did they put in a cheap non-variable pump?
